20" wheel owners question!!!
happy
p.e.i canada
Onm y 02 gts just put on iforged 19/20 with eibach lowering springs, seems like im rubbing a bit on the rear. what do guys normally do to fix this problem?? want a adress it before i get a wheel allighnment done !! Thanks!
Red Snake
NashVegas
It depends on your tire. If you run an Invo in 345/25/20 you shouldn't be rubbing. If you run the Michelin tire in 335/30/20 you will likely rub.
Mopar Boy
Ontario and Ohio
The Pirellis I had were 345/25/20 and the PS2s I now have are 335/30/20 (I believe....or were they 335/35.....hmmm. Now I am second guessing myself in my old age). These have touched twice. Now I am lucky as I am an ACR. I can adjust the back end if I needed to but I am guessing due to the stiffer 1100 lbs springs, I don't rub.
costanZo
Haverhill, MA
I have:
Michelin Pilot Sport PS2, 295/30/ZR19
Michelin Pilot Sport PS2, 335/30/ZR20
and there is ZERO rubbing; however I have KW2's, not eibachs'.
I am considering these as my next set tho:
Nitto Invo, 285/30ZR19
Nitto Invo, 345/25ZR20
ViperGTS
>>19/20 with eibach lowering springs<<<
You should be fine with driving to the next coffee shop at 30-50 mph :rolaugh: that's exactly what the VIPER was built for!:drive:
And, please, stop whining about driving issues when you do things like 20" wheels and lowering springs but not a full setup like KW.
slitherv10
I have the Pirelli P-Zero rosso set up with the 345/25/20 rears and Aldan American 754 Coil overs and absolutley no rubbing at all. The key is the 25 sidewall profile. If you go 30 you will rub.
H
happy
p.e.i canada
Not whining big fellow just asked a simple question, before i took it in to have its allighnment done!! And yes 335/30 20 on rear, once there gone will go 345/25 for sure thanks everyone!!!!!!
ROIII
