2001 RT 10 Idle Problem
grabber
I own a somewhat modified 2001 RT 10. Headers/cam/rockers/exhaust/intakes/etc
A problem has cropped up that as I drive the idle wants to stay at 2000RPMs. The result is lugging in gear and a 2000RPM high speed idle when I take it out of gear and put it in neutral as I slow for a stop.
The idle returns to normal as the speed of the car goes under 10 MPH.
I have replace the throttle position sensor.
Any experience with this?
Purdue_Boiler_Viper
Indy
Do a search for "hanging idle". There have been various reports / solutions. If all else fails, a Roe PCM will do the trick, but at quite an expense.
wizzlepoof
