2009 ACR and Splitter modification question
Tim Purtell
Plano, TX
Have a new 2009 ACR (YEA!!!!!). I trailer the car to events and want to use the frame slots with R hooks to secure the car to the trailer. The rear slots are easily accessible - no problem. The front slots (normally accessible on the car) are partially blocked by my new $5000+ carbon fiber splitter. A non-official recommendation came from a tech at the dealer was to take a dremel grinder and cut the splitter area that partially covers the slot and remove about 1/2" by 1/2" section of the carbon fiber there to open up that slot area so it can be used as the anchor point it was intended to be. He said that using the anchor slot "as is" with no cutting will absolutely stress/break the splitter and in looking at it, I absolutely agree. A friend who owns an ACR views cutting (even a little) the splitter as a 'terrible idea' and uses axle straps up front instead.
Is it OK to cut the splitter away a bit to gain access to the slot? Thanks!!!
SCLSSRT10
I cut the splitter on my CC so the the slots were accessable. I did that 2 years ago and have had no problems with the splitter since then. That is the easiest fix and no problems.
SoCal Rebell
Mission Hills, Ca USA
The easiest way is to buy an open center trailer. I've owned a few, they're light and can be towed with any V8 SUV. With the open center you crawl under the trailer when you hook it up and the straps come down out of the way of the splitter, it works great, secure and no mods.
ViperGeorge
Greenwood Village, CO
Makes me shiver to think about cutting the splitter but I guess if you measured twice and cut once and were extremely careful then it might be ok.
Viper X
I cut some very small sections out of the rear / sides of my CF splitter to allow use of the oblong holes in the frame for tie down.
Towed to about 9 events this year, no issues.
Just mark it, take your time and cut it out. Dremel steel cutting tool works very well.
Really silly that Dodge didn't allow for us to tie our ACR's down with the OE frame holes.
Dan
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Dremel The Splitter...
DONT use axle-straps and risk the harmonic issues of bobbing-floating suspensions while trailering...or possibly bending an A arm.
T
Tim Purtell
Plano, TX
Got under the car to cut the splitter back a bit and it is not clear on just how much to take. Attached is the close up picture. The trouble is that the splitter is about 3/4" away from the frame/slot so I'm not sure how much to take. Anyone that has cut it back ... do you happen to have a picture of how much you cut back and what tiedown you use that keeps it away from the splitter?
Thanks!
THEMASH
VA/KSA
I spoke to Chuck Tator about this when i first bought my ACR, and he said to cut the splitter as well.
FrankBarba
I use axle straps & attach them to the frame, no troubles & no issues with re aligning car.
Viper X
steve911
Cottage Grove, Wi.
Hey Tim,
I cut along the angled part of the splitter and left the bend / fold intact for strength, then cut the bottom back about even with the bottom of the frame. I took out a small, triangular piece of the CF.
I use "R" hooks with a chain like attached to them that I bought from: Towing | Recovery | Repo | Safety | Service Truck Equipment and Supplies - AW Direct
Good luck,
Dan
I agree with DAN 100%. Cut the splitter. I cut mine just enough to expose the full slot in the frame. I use R hooks too. Have trailered that car thousands of miles over some pretty crappy roads and have had NO problems.
Steve A.
T
Tim Purtell
Plano, TX
Cut the splitter as shown in this picture. I trailered it to the track this weekend and everything worked out well. Thanks to all for the advice.
No members online now.
ViperGear
