2010 ACR leak near front wheel?? Shock?
nutrientcobra
Just noticed when pulling my 2010 Viper ACR out of the heated garage for a warm up that there was a teaspoon maybe of clear heavy oil on the floor. It is just inside the drivers side wheel on the front. It is straw colored and clean looking. Any ideas? I have to take it to the dealer when the gravel clears and will have it checked out. But thinking it may be a shock. It has about 1400 miles on it. Thanks
N
nutrientcobra
I'm thinking shock is leaking. Pull the wheel and feel around the shock, see if there is any oil there.
Thanks, are these shocks still made do you know? I was reading a maker of some ACR shocks is out of business. Was wondering if they are, what will the factory replace them with? Thanks
kcobean
Sterling, VA
You're probably thinking of the DS shocks that came on the later 2nd Gen ACRs. Your shocks are readily serviceable or replaceable and will be under warranty.
N
nutrientcobra
Thanks, and you are correct about the shocks 100 percent. I was thinking of the older models. Just found it on the net. By the way, do you know on these shocks how long the warranty is? The site say lifetime against manufacture defects. Than I saw somewhere 12 month. I will find out tomorrow but thought I would ask. Thanks:usa:
Art 138
Davie,FL
So KWs were not installed on MY10 ACRs...interesting; anyone know why the change to DS...?
kcobean
Sterling, VA
No, Dynamic Suspensions (DS) shocks were installed in 2000-1/2 through 2002 MY ACRs and are no longer manufactured or serviced by Dodge. That's what NC was thinking of. That's not what's on any Gen-4 Viper. The 2010's have KW's.
Yellow32
texas
My '09 had a leaking shock from the factory, had it replaced before tracking it the first time...seems to happen...
Kkustelski
