viper vince
- Joined
- Jun 29, 2013
- Posts
- 154
- Reaction score
- 0
I want to see a 2010 ACR go against a GEN V car on the drag strip and see a head to head test with two novice drives.
ACR on the drag strip? You realize a stock regular Viper will beat an equivalent model year stock ACR (slightly) in the 1/4 mile, right?
This. ACR is the slowest Gen 4 in a straight line, due to the aero drag. It just looks the meanest. Gen 5 is geared much better for 1/4-mile.
And, I'd rather not watch two novices try racing. I'd rather see two good drivers go at it.
I dunno...I think it would be kinda funny to watch if they both stalled at the line.
It is slowest at the top end, drag really starts affecting the car above 150 mph, this is why downforce for ACR is given at 150 mph. On the track, you will not come close to speeds where you notice the difference.This. ACR is the slowest Gen 4 in a straight line, due to the aero drag. It just looks the meanest. Gen 5 is geared much better for 1/4-mile.
Do not bet on anything, Gen 5 made some improvements on tire related lift but downforce generation still belongs to ACR, unless you equip Gen 5 with similar set up. Just because drag and downforce are there, this does not mean they are the dominant factors since there is body and tire lift to consider.No contest the Gen V will win. I start feeling aero drag around 80 mph in my ACR, the down force starts working way before 150 mph.
How did you come up with these numbers? At 150, ACR generates about ten times as much downforce as base car, where are the numbers for the lower speeds coming from? Are we talking about NET downforce after subtracting the lift?The ACR produces twice as much downforce as the stock coupe as low as 65mph.
The numbers I see mention base car producing 100 at 150 actually.I came up with those numbers at around ~65mph the ACR is producing ~200 pounds of downforce, and the numbers I have seen in the past is the coupe produces ~100 pounds.
@~120mph the ACR is producing anywhere from ~600 to ~700 pounds of downforce depending on the position of the rear wing.
Where is this graph from? This graph looks very misleading, is it from a Chrysler sales brochure?Aerodynamics start coming into play as low as 40mph, this is why manufacturers work on improving the Cd on everyday road cars as well.
Anyone have a stock Gen 4 in Houston? I have a stock Gen 5 and am willing to participate.
What matters is the difference between the downforce and liftforce, I hate to see Chrysler claiming numbers based on "typical sports car" lift being used to make any claims. Is this another graph from a sales brochure? I hope you realize how meaningless this graph really is...That was my point, at 65mph the ACR is producing 2x the downforce as the coupe at speed.
I get very suspicious when "typical" values are used for comparisons. I am not trying to start any argument so I am going to bail out. Sorry for any disruption, I think it is better if I just keep building my own stuff instead of arguing about designs of othersComposites World (magazine)
http://www.compositesworld.com/articles/composite-wing-key-to-high-speed-stability
Attribution is Chrysler, but likely from SRT group themselves. Why would you say it looks misleading? Most car designs produce lift at speed unless they have a lot of aero tweaks.
