3D print an interior door sill plug
maverickagm
New Westminster
These should work for 1992 - 2000
This was supposed to be a quick and easy design, but it took some effort to get the button/dome top to not look crummy and to align the layer lines so the legs wouldn't snap off....
Photos and instructions are on the printables.com link below, but In short, print in ASA/ABS, cut the included support piece off. touch up the edges with some sand paper and then it should look serviceable.
* Update Jan 17, 2024: The link now contains both inner and outer plug models.
GTSnake
Motor City
Just curious when would you need to pull that plug. In case the door is flooded?
GoViper
Ohio
Will you sell the printed plug for those of us that don't have a printer? thanks
TEALLIFE
Fort Lauderdale
love people making things that we cant find anymore! Great stuff.
Although the ones i got on amazon did the job perfectly.
GTSnake
Motor City
When working on the exhaust, you pull them out to access the bolts holding the rocker panels on. I was missing 3 when I bought the car.
Oh those plugs... I thought they were under the door. This is why I don't like other people working on my car.
M
maverickagm
New Westminster
There might be some confusion on which plugs these are. They're under the door when the door is closed. There's 4 per side on my 93. I circled 3 in green on the driver's side in this photo (ignore the messy garage!):
luc
Paso Robles CA
I’m talking about the smaller plugs on the plastic trim inside the car. To the right in your pictures
M
maverickagm
New Westminster
Ohhh.... I found a photo. I had no idea there was supposed to be plugs over those screws. I don't have a single one. Well dang... Guess I'll make those next.
Dan Cragin
LA, CA
Those plugs are not serviced by Dodge, but you can find them in the aftermarket. Its all in the details, and I can understand that can drive you crazy.
TEALLIFE
Fort Lauderdale
Yes, those are the ones i got on Amazon
GTSnake
Motor City
Wow, 50 pieces! If someone buys these you can send the rest to the other Viper brothers.....
luc
Paso Robles CA
that would be fantastic if you could. Mopar part # was 4848881AA
luc
Paso Robles CA
they were serviced, part # 4848881AA, but have been NLA for years. they go on top of the screws holding the sill cover interior
luc
Paso Robles CA
My mistake, the correct part # for the small plug on the inner sill is:MB68DX9
