Slithr
Is the harness below a 5 or 6 point
Track Rats ... what's the diference as in pros/cons of each (I'm aware of the additional point thing
6 point and the advantage is that you cannot slip under the belts in a crash if you are laying down.
do you have a rollbar? Are viper roof's strong enough to not crush ya?
It is also worth checking with the driving club or organization sponsoring track events as some may require 6 Pt harness.
PavenomRT/10
You can sit in my car with 6 points the next time you see me Alan (Belinda can as well if she is with you). Maybe someone else here in town has 5 points you could sit in.
6 point. A 5 point has a sub belt that would go straight down the front middle of the seat and would attach to the floor in front of the seat. Most knowledgable folks would say that 6 points are safer. Some might say that 6 points are less comfortable. I use 5 points as that's what I've used for a long time. There was a thread on here once about a rally driver that hit a tree or something while wearing 6 points, it did very bad things to his family jewels if I remember correctly. Links to pics would make you want to throw up. Morale of the story was that the belts stopped his body from moving forward but not what he had down below if you know what I mean. (Mods, hope this isn't too graphic) Not sure a 5 point harness would have been much better but it was reason enough for me to stick with the 5s.
Somewhere along the line I was told that racing harness (5 or 6) was not legal in Texas. Did I miss something here? If you're taking a street car out on the tack, is it OK with the local laws to run the same belt setup on the highways?
Did not see the thread Mentioned below.
Is it possible that the harness was not properly adjusted? When I read up on 6 point harnesses awhile back the manufacturers made many claims about anti-submarining with 6 point harnesses.
Alan:
Team Tech makes a good set of 6 points that Beth and I have been happy with, can get stiching to match your car's color and to solve that fit problem you need to get your own Viper! Ask Mike and Karin, worked great for them too! The belts can be tucked away for street driving. Glad to hear your considering the Autoform, great roll bar!
Hope the rain stays away for C&C as well.
Richard
Wrapping the sub belts over the front of the seat will not pass tech inspection with many track events, and it will not really protect you from submarining either. The 6 point teamtech belts allow you to sit on the sub straps so you dont have to change out for a racing seat, they are custom designed for the Viper. You can tuck them under the seat when not using.
I stopped bothering with those single digit safety harnesses. Those things are death traps. I installed an ultra high tech 87-point harness. It only costs $32,000 and the driver can't move any part of his body more than 1/8 of an inch but it is the latest and greatest in safety and no expense is too great for safety.
