Received a message back from Fat Albert on the 700hp Viper engine. Build specs and dyno as follows:
Motor complete - All parts are new
My Cost of Building Motor $40,626.10
TOTAL ASKING PRICE WITH EXCHANGE $18,000.00
(Customer Pays Shipping & Crating)
Motor Built by Mach Development for me. You can check out his
Website if you want to at
Home Mach builds motors for dragsters, funny cars, street cars.
COST TO BUILD RACE/STREET ENGINE - LONG BLOCK
TOTAL COST OF PARTS & LABOR
SEAL RINGS - J&E $ 188.80
RODS - MANLEY 800.00
PUSHRODS 210.00
10 ROD BEARINGS 82.30
BUILD MAIN CAP TIE BARS 220.00
ALIGN HONE MAINS 295.00
BORE & HONE W/TORQUE PLATE 575.00
DRILL OIL HOLES IN MAIN SADDLES 85.00
BUILD OIL RESTRICTORS 240.00
RESIZE RODS 260.00
PIN FIT RODS 120.00
PIN FIT PISTONS - J&E 120.00
MACHINE PISTONS 340.00
COAT PISTONS/RODS/MAIN BEARINGS 550.00
SCALLOP OIL HOLES IN CRANK 250.00
POLISH CRANKSHAFT 90.00
CRANKSHAFT 3,200.00
ATI RACE CRANK DAMPER 725.00
CRANK - GRIND & NITRITE 985.00
BALANCE ASSEMBLY 450.00
REPAIR HEAVY METAL IN CRANK 250.00
CAMSHAFT- SPECIAL CUT - .583 LIFT 700.00
DEGREE CAMSHAFT 120.00
FILE FIT RINGS 160.00
ADJUST CAM END PLAY 75.00
CORRECT WINDAGE TRAY 180.00
BUILD OIL PAN SYSTEM 240.00
GASKETS 280.00
LIFTERS - NEW - RESIZE TO FIT 900.00
MAIN BEARING ORANGE HEMI - SPECIAL CUT 1,200.00
PRESSURE TEST BLOCK 425.00
HEADS POLISHED & PORTED 8,460.00
BLOCK 6,200.00
INTAKE W/INJECTORS & THROTTLE BODIES - 68 4,200.00
RACE OIL PAN AND OIL SYSTEM 2,800.00
WEBER ALUMINUM FLY WHEEL (BALANCE & CERTIFIED) 600.00
CENTERFORCE PRESSURE PLATE & CLUTCH (BALANCED) 550.00
LABOR TO BUILD MOTOR 3,500.00
TOTAL COST TO BUILD LONG BLOCK $40,626.10
THE COMPANY “COMP CAM” OUT OF CALIFORNIA MADE THE CAM.
HYDRAULIC COMP CAMSHAFT SPECIFICATIONS (SPECIAL CUT FOR VIPERS):
INTAKE: DURATION - 289 DEGREES LIFT - 540
EXHAUST: DURATION - 300 DEGREES LIFT - 583
BEST CAM FOR ROAD COURSING AND STREET
The following is what was done to the heads:
POLISHED & PORTED $2,495.00
INSTALL VALVE GUIDES 225.00
ANGLE CUT 380.00
RADIUS VALVE JOB 750.00
VALVE SPRINGS 347.00
RETAINERS 210.00
LOCATORS 88.00
VALUE LOCKS 45.00
NITRIDE ALL SPRINGS & VALVES 275.00
VALVE JOB 340.00
NEW VALVES 635.00
TNT ROLLER ROCKERS - 1.70 1,695.00
VALVE COVERS 600.00
PRESSURE TEST & FLOW BENCH HEADS 375.00
TOTAL COST OF HEADS $8,460.00
This dyno sheet listed below is for a 1996 to 2002 Viper. It has a 583 hydr lift Comp Cam that gives it 800 hp and the 2003 & up motor has a 540 hydr lift Comp Cam that gives it 700 hp.
DYNO SHEET - ENGINE VIPER WITH HYD COMP CAM
RPM TORQUE CTORQ BHP CBHP BSFC FUEL
3798 738.4 816.7 534.0 590.6 1.322 638.1
3900 743.9 822.8 552.4 611.0 1.308 653.0
3999 747.2 826.4* 569.0 629.3 1.280 658.1
4098 743.7 822.5* 580.3 641.8 1.244 652.3
4200 741.3 819.9 592.8 655.6 1.183 634.0
4300 737.4 815.6 603.7 667.7 1.151 628.3
4400 733.1 810.8 614.1 679.2 1.113 618.1
4500 728.1 805.3 623.8 689.9 1.070 603.5
4600 719.9 796.2 630.5 697.3 1.077 613.9
4700 712.3 787.8 637.4 705.0 1.081 622.9
4800 705.4 780.1 644.7 713.0 1.087 633.4
4900 699.0 773.1 652.2 721.3 1.049 618.3
5000 690.7 763.9 657.6 727.3 1.073 637.9
5100 681.3 753.5 661.6 731.7 1.068 638.8
5200 674.3 745.8 667.6 738.4 1.082 653.0
5300 663.7 734.1 669.8 740.8* 1.068 646.5
5400 648.3 717.0 666.6 737.3 1.071 645.3
5500 633.9 701.1 663.8 734.2 1.067 640.5
5600 614.2 679.3 654.8 724.2 1.086 642.6
5700 589.9 652.4 640.2 708.1 1.097 634.6
5800 574.9 635.8 634.9 702.2 1.139 653.4
AVG 691.5 764.8 626.3 692.7 1.129 636.5
