KNG SNKE
Was scanning through the owners manual and it said anything over 91 octane is not recommend. Can anyone explain why?
They did not make 93 octane when your car was made?
Missed it at the print press?
I have the manual for the '01 (mine is an '01) and it says the same thing. I wasn't aware that you could have too high an Octane rating
Within reason?
Are they sending a message to not run 104 with cast pistons???
Good question, but you'd think they wouldn't specifically isolate a commonly available grade of standard 'street gas' if 'within reason' is what they meant. 93 wasn't uncommon at all in '01/'02.
We need Tom Fuel & Lube GoR to comment on this.Was scanning through the owners manual and it said anything over 91 octane is not recommend. Can anyone explain why?
so all in all, go with 91 is what your recommending? just want to clarify. ive always run 93 in my fast car, but it was turbo'd.
Ford was the first to say this. The higher the octane value of gasoline, the less volatile it generally is. Lower volatility means that the rate of changing from liquid to gaseous is slower. Since an engine burns fuel vapor and not liquid, a poorly volatized fuel charge will be lean, and can make the engine hesistate or stumble. This might be a minor annoyance to the driver, but it is critically important in emissions testing. Of course, there are a huge number of other factors that also affect this; ambient temperature, coolant temperature, engine speed, load, in other words - almost everything else. The recommendation to not use higher octane is good advice, but probably actually makes a noticeable difference in very few examples. But, since there is no additional performance gain from using an octane value that is higher than needed and there is a potential performance debit from using a high octane fuel, it makes sense to only use exactly what the engine needs.
Thanks Tom.
Seeing as my choices are 87 89 and 93, well...
Dave, I'm with you that's the same choices I have....Next fill up. Viper has a 19 gallon tank..Let's see now 6.5 gals 87 + 6.5 gallons of 89 + 6 gallons of 93= 91. Got it!!!!
The oil companies advertise their highest octane because (as of a few years ago) the increased cost per octane was about 2 cents, but the retail price increase per octane number was 5 cents. They justified it by putting 0.1 to 0.25 cents worth of extra detergent in the premium grades.
If the spark timing or compression is changed to take advantage of octane (as does a knock sensor) then sure, you'll get more power output. Otherwise, there is no advantage and possibly a small debit.
You naysayers about how little it matters - the higher octanes are less volatile, so the gasoline doesn't become vapor as quickly and is more likely to stay a liquid droplet. That means upon entering the combustion chamber and flying past the open intake valve, the droplets don't begin to swirl and tumble; they keep going and impinge on the cylinder wall. Once on the wall they stay cool and do not vaporize upon the rising piston increasing the compression pressure (generating heat.) Consequently the fuel is wiped off the wall by the rings and enters the engine oil. Gasoline likes to oxidize, so it consumes anti-oxidants, allow oil to thicken. Gasoline is thin, so the overall oil viscosity is lower. Gasoline decomposes to initiate deposits. Did you know that about 25% of the fuel additives end up in the oil for this reason - those additives are big, heavy molecules that splat on the cylinder wall? And that engines running moderately well can accumulate 2-4% gasoline because the oil never got hot enough to boil it off?
Is it a tremendous issue? Not really. I'm just letting you know because of the tendency to think that using 93 or 94 or whatever the highest available (beyond 91) is automatically good or can't hurt.
