94 R/T10 dies on acceleration,after warm!Guru's help!
TOOOFST
Barrington,il
94 R/T10 dies on acceleration,after warm!Guru\'s help!
My buds car has 30000mi and recently after the car warms up it dies when giving gas hard in 1st gear.Its totally fine when cold.Dealer replaced the crank trigger,map sensors and wiring harness with the 5volt reference.Still not fixed!Dealer stumped!!Help viper brothers and sisters.
Fort Lauderdale, Florida.
Re: 94 R/T10 dies on acceleration,after warm!Guru\'s help!
May be a bad ground.... Possible battery shifting around. As heat builds so does resistance.
Another possibility, we once had the same problem with a '95 R/T. The complete factory harness went bad and needed replacement.
Good luck,
Doug
T
TOOOFST
Barrington,il
Thanks DLM,we did replace harness,we'll replace battery anyway.
ViperGear
