HELP HELP HELP!!!
Cape Coral, FL
Well hell. Haven't you ever had a puzzle you wanted to solve? I'm not going to **** out. Yes, I made a mistake with crossed wires. Good grief. Happy to drive you crazy because you're so smart. :)
I've given TONS of explanation here. What's your opinion?
My opinion is that I don't have an opinion. Trying to diagnose something like this when you don't have the proper tools to give me concrete answers makes any realistic diagnostic tree completely useless.
Explanation without fact is nothing more than a jumble of questionable items. What I *DO* know, is that you have introduced so many potential issues with the parts-swapping that even if I had my hands on the car itself, I would probably find the problem, and then tear the whole thing down and do it all over again to make sure no new "next issues" have been introduced accidentally.
I have solved more puzzles than I care to remember... thats literally what I do. None of them were solved by accident or chance.
I am extremely blunt... or as most people would say: a dick. I am well aware. Doesn't make me any less right, or any less good at diagnosing things. And dont think I am talking to just you... I am talking to any of the other owners that do the same thing, or any of the members that throw out ideas without knowing the first thing about how systems actually work or what the diagnostic process should be, as that encourages part-swapping behaviors. In cases like this you should ask for help at minute-1, long before the waters are muddied with other potential items from someone having their hands in everything. A proper scan tool, along with a Fuel pressure gauge, ignition, injection, and compression test would have given all the pertinent data back before you laid a finger on replacement items.
Go back to the beginning. Check EVERY SINGLE CYLINDER for spark. Check the wire routing again. Check with a Noid Light that injectors are actually actuating. Check compression on at least a few of the questionable cylinders. Check for soaked spark plugs. Check for closed plug gaps. Check for wiring damage. Check for a bogus PCM/ICM repair job- They didnt come from us, so by default they are questionable if they had any "repairs" done. Check for fuel pressure drop-off after prime to make sure it doesnt drop like a rock indicating a major bleed off into the engine. If everything tests OK, start the engine, and unplug the fuel pump relay while its running. If it runs like crap, then cleans up, and then dies... that points to excess fuel being dumped into the manifold somehow. If one bank is bone dry, but shows good compression, ignition is there, and injectors pulse... then there is an issue with the rail being plugged. Without more data points, I am guessing, same as you.
These are all tests that come long before replacing parts.
TEALLIFE
Fort Lauderdale
Good stuff!
GunnsDonovan
North Carolina
Triangle of combustion: Air. Fuel, Spark.
Quit with the parts cannon crap. Learn it and fix it.
Is the car underwater? Is there a raccoon stuck in the intake plenum? No? Then you likely have no issues with airflow.
Check for spark. I would suggest an oscilloscope, but I think that's beyond your technical capacity right now. You can ohm out the plug wires and can check the coil primary resistance with a decent DVOM.
Check for injector firing. As was mentioned, use a noid light to confirm power command from the PCM to each injector. You can also use a mechanic's stethoscope or a long screwdriver with the handle placed gently to your good ear. Listen for a cyclic clicking on each injector while the engine is running. If the noid light blinks while running, but the injector's not clicking...
If you have a dead bank of cylinders, the first thing to check would be the ground to the injectors; they share a common supply voltage connection.
Right from the FSM:
FUNCTION
The fuel injectors are solenoid operated valves that deliver fuel, in a metered amount, to the combustion chambers of individual cylinders.
OPERATION
When the solenoid coil is energized (on), the plunger is retracted lifting the needle valve off its seat, allowing fuel to be injected into the combustion chamber. When the solenoid is de-energized (off) spring pressure closes the valve.
This vehicle uses bottom fed fuel injectors. The bottom of the injector is fed with fuel from a passage in the intake manifold.
The ASD relay supplies voltage to the fuel injectors. The PCM and ICM control ground paths to fuel injectors, by switching the ground path on and off. The PCM and ICM can fine tune fuel delivery adjusting injector pulse width (on time). The PCM controls injectors 2,3,4,6,7,8,9,and 10. The ICM controls injectors 1 and 5, according to PCM instructions.
B
Bigsnow
Atlanta
Just damn. ---- CRACKED INTAKE!
Hairline intake manifold crack on #9 cylinder. The crack also raised the surface mate-to-head gap to affect Cylinder #7 and a little on Cylinder #5.
Also, had suspect 2 faulty ignition wires, dirty IAC, and old gas.
B
Bigsnow
Atlanta
Hold that...!!! I also found this. Besides the cracked intake on #9, had this little **** on #10. Bent pushrod. That's why when I put my hand on the exhaust it wasn't being pushed off with pressure. The bent rod was holding the intake valve open.
Glad it's working out for you now. Mechanical stuff is pretty straightforward. 4-rib manifolds are not exactly plentiful, but 3-rib Gen 1 units are.
