You need to figure out if the ASD relay is actuating or not. It could be on the Control side of the relay, and all of the high-current wiring and fuse are perfectly fine.Well, there is no power to the injectors. Checked the fuse and ASD relay, both good. There must be a wiring fault somewhere. More time on my back under the dash.
Scan the module with a Diag tool. Anything relating to ASD failure should show up.
