My A/C stays charged for a couple of months.....time to change the o-rings to see if that's where the refrigerant is leaking out.
I usually just start taking stuff apart and figure it out as I go
, but with the A/C lines one wants to be ready to do the operation fast in order to prevent moisture absorption by the oil in the system.
So, I'm double checking (hopefully) with someone who's changed out the A/C o-rings before.
Below is a pic of what the manual says are the blocks for the inlet and outlet of the compressor. Looks like two blocks with one bolt each (but it might be one block with two bolts and two hoses).
Question for someone who's been there - Are these the only two bolts required to expose the o-rings, and are the o-rings part of the block that comes away from the compressor or are they in the compressor?
