Abs Problem help !!
nakata10
texas
I have a problem with my viper srt10 2003, I changed the abs pump and when I started the car I had an alarm on the abs on my dashboard, I connected my scanner and I got these codes: P0A1D and P001D with the description "please refer to the manual of service ", I've already been researching but I can't find a description for those codes, someone knows what the codes refer to, thanks for your help.
TexasViper35
I really don’t know if this is applicable to your situation or not, but some cars have a protocol to follow to reset the ABS. If you use Google you can find them.
One that I saw on YouTube was:
1. Turn the key to On, not starting the car
2. Push the gas pedal to the floor and release, do that 3 times
3. Start the car
If that doesn’t work, drive it in excess of 15 mph and it should reset.
Anyway those are just two that are for Dodge, there may be another specific to the Viper, or your issue may not have anything to do with a protocol at all. Good luck.
