ACR 5-PT Harness Mounts
Henry Cone
Raleigh, NC, USA
I hate to say this but much better 5 points are available than the ACR ones. If you are getting them for track use I would suggest geting Team Tech belts (we got ours from Keith Moody at Bobby Archer's German Motor Works) as they offer the best protecdtion (IMHO). If this is more for looks then others can be had cheaper than the Team Techs...
The mounting locations are in all GTS's from the factory as far as I know - thanks to Dodge for some good planning!!! You do have to cut slots in some very expensive bulkhead pieces to install the belts, though...
We have installed belts in 3 GTS's now so feel free to contact me with any questions....
Jerry Scott[CO]
Morrison, CO, USA
I am also researching the 5-point belt for a GTS and have learned that the most desireable set-up seems to have the cam lock on the crotch belt, so that it can be pushed under the seat when not in use. The other belts that have the cam lock on the shoulder straps or lap belt, get in the way when getting into the car.
