ACRsnake
hi, i am having a problem with the rear tire not holding pressure , there is no nails/holes in it. Its leaking on the contact area with the wheel on the inside, if i over inflate to 40 psi it holds for a day or two . it started leaking slightly from the start , then we took the tire off to check it and since i put it back its leaking even more . Its on a 1100 mile 09 ACR .
Do you have any experience with such a problem before ?Is it a defective wheel or tire - both look ok to me ?
I really appreciate your help.
