I know several other guys either have done or are in the process of doing this upgrade.
After trying it on the track, I couldn't recommend it more....
I got some ACR-X Brembo front rotors and PFC pads from Jon B. Also got some new Stoptechs with Mintex pads for the rear. (I was replacing slotted Eurotech rotors) I was able to try them out on my last track date of the year at Road Atlanta...
They were awesome to say the least!!!!! There is more "range" in the pedal. Pedal feels firmer and therefore more confident going hard into the corners. You thought it was fun to pass other type cars in the braking zones because of our brakes before, this set up is even better..
These are the new Brembo X- rotors. You can see the additional rotor surface area compared to the new Stoptechs...
On the left are the PFC pads for the new X-rotors. They are next to some OEM size Mintexpads.
MORE pad contact surface and MORE rotor contact surface = MORE BRAKING....
I am using the new rotors/pads with Titanium pad backing plates, braided brake lines and the ACRX brake duct system.
