Added a little boost to me Heads/cam Cream puff *dyno*
FastMatt
alamogordo nm USA
Here is the before and after Dynos of my Striker heads/cam 2001 Cream puff.
Things I changed/added between these 2 dynos
Paxton blower kit (3.25" pulley makes just under 7psi of boost on my car)
Larger heat exchanger and pump
larger injectors
DC re-tune SCT for the larger injectors
2 Walbrow HP in line boost pumps
KB boost-a-pump on stock intake pump
Changed from Balenger "try Y" headers, to a AR 5 into 1 merge header
Changed from 3.55 rear gears to 3.33 rear gears
Went from 355/25R19 rear tires to 345/30R19 rear Nito Drags
Still a stock bottom end, and my Compression is 11.1 to 1 with the Shaved Strikers, I'm prity sure with how much timing I am pulling I could run on pump gas, BUT I'm mixing 25% Q16 in the tank with the 91 piss water pump I get abound here just to be safe.
Big thanks to Dan and Chris from DC Performance for getting me most of these parts, and E-mailing me the tune for the larger injectors.
DrumrBoy
GA
That's great power, I'm actually most impressed by the 611 NA. Nice build.
Red Snake
NashVegas
Awesome numbers. I'm not sure why you wouldn't throw some forged slugs in there. Cheap insurance IMO. I hope you never experience any detonation.
Kudos to you for the great numbers. Very nice. ;)
