Another "spot the problem" ebay auction:
PDCjonny
Re: Another
A 1994 GTS alone would be quite the collectable, but factor in an automatic tranny and your off the charts. :)
trainville
Oregon
Re: Another
Hmmm.. nope. Other than Gen 2 wheels, which I prefer anyhow. C'mon I give up.
GotAViper
Annapolis,MD
Re: Another
says 94 VIPER GTS WHEELS.... hes pointing out it has gts wheels ??? not calling it a gts. just looks confusing
also ebay doesnt let you put manual i thought for vipers? seen that problem alot on there.
D
danfromohio
Cincy, OH
Re: Another
Ahh, I think you guys are right, they are talking about the wheels. And you are correct that all Vipers listed on ebay go in as automatics.
94RT10Ohio
Northwood, Ohio
Re: Another
Other than what was pointed out, the GTS in the title just refers to the wheels, not the car, I do not see any issues.
The headlights are just the lighting, the sun light is coming from the right side of the pic.
Dv8tor
Boca Raton, Florida
Re: Another
I am trying to figure out the purpose of this picture
This photo clearly shows that the owner took the car to the track and has reved the engine way past 7000 RPM and almost took it around back to 0 :2tu:
STUGOTS
NY/CT
Re: Another
other then the fact that there is a silver car parked pretty close to the snake in one of the pics. nothing
Matt M PA
Langhorne, PA USA
Re: Another
Loosk good to me as well, except for the two punctures in one seat and the tasteful? carbon fibre BS on the dash. Ick.
viperkraz
Re: Another
I've seen several 94&95's with 4 rib intakes. So who knows what is correct? My 95 had a 3 rib.
bth1
New Jersey (Union County)
Re: Another
How difficult would it be to remove that carbon fibre? I assume it is held on with an adhesive. I figure once removed the dash would then have to be painted.
bth1
Re: Another
John Johns
Thornton, Co.
Re: Another \"spot the problem\" ebay auction:
No clamp on idle hose at air cleaner. Dirty brake fluid. No MGW goodies?
Gerald Levin
Indianapolis, IN
Re: Another
The ad said NO RESERVE, but it has a starting bid of $31,440.00
Dont you love those "no reserve" auctions with a starting price that is more than the value of the car? I've run many, many no reserve auctions starting at $1 and high bid get it. With the hundreds of thousands of viewers on ebay, you are not going to sell you car for $2.50. Those "no reserve" actions with high minimum bids kill me.
94RT10Ohio
Northwood, Ohio
Re: Another
If a 95 has a 4 rib it is not original. The change was 1/2 way through the 94 model year.
BLWNV10
Re: Another
Another thing to look at. This dealer has 161 positive feedbacks, and a 100% rating.
bmillionaire
