anyone have a set of O2 sims?
PS78
UK
same question for me so i'll tag it on Toby's old thread!
anyone have a set to sell on?
or where best to get a new set of sims please (for an 02 RT)?
*Thanks*
PS78
UK
thanks Chuck for tip but 1 of the rears is not working, so rather than replace with same i'm changing them both for sims.
cheers too psycho1 LoL!
PS78
UK
---deleted!---
PS78
UK
Heyy not a problem!! there's plenty i don't know yet about modded exhaust systems; could there ever be a use for them up front?...i guess not! ;)
Sorry Pete thought you were after the 02 Sensors.... My mistake....
GTS Bruce
Orchard Park,NY,USA
Let me tell you this. I have used syms. Disconnect the battery,reconnect and you can't pass emissions with the syms although no check engine light shows. The first test the ecu does is a sensor heat up test and the syms will not duplicate. You need to plug in a good sensor and at least let in dangle in the air. After the heat up passes you can disconnet and plug in the syms. Seems the ECU only checks the heat up circut if the ecu or battery has ben disconnected. GTS Bruce
Kkustelski
