Hey guys, in February I purchased a Paxton kit. After a couple months of doing everything else to the car I've had a change of heart and I'm going a different route with it. I installed the system on the car but never got to the finish line to actually fire it up. So the blower and all the components have seen 0% Run or Road time.
Heres what I'm trying to unload:
Paxton Novi 2000 System for 2003-2006 Viper
The innercooler has been modified to run utilize a TiAl 50mm BOV
Upgraded bigger water cooler (For Air-Water inner cooler)
Upgraded Bigger Miezer water Pump ( For Air-Water inner cooler system)
All lines and fittings for the water system were made and plumbed from black braided hose and Earls aluminum fittings ( No Rubber lines and Brass Fittings here)
Custom Brackets to mount all of the water system ( See pictures)
DLM Tensioner upgrade
7% larger crank puller for 2 more PSI
3.5" Blower pulley for 2 more PSI ( Smaller than Paxtons shipped Pulley)
( the original sized pullies for the crank and blower will also be included!)
Roe Racing High Flow Cats with braided Flex tubing
All nuts and bolts for the whole package have been changed to Stainless Nuts and Bolts.
Im looking to get $8000.00 OBO plus Shipping in the CON-US.
PM me or email me please at [email protected]
If your looking into getting a Paxton system you can see I have multiple thousands invested on top of the system to improve it. Once again Nothing has been fired up, the water/cooler has never been filled.
Water/ reservoir tank/ horn bracket
Braided Oil return line
Black lines are Braided for water system...Red fitting lines are oil cooler lines and are NOT INCLUDED
WaterJetted brackets for innercooler
