You're killing me smalls! I think we are not on the same page. This isn't my first time using a buffer or doing a full paint correction, not even close. I am using the same technique as you in your video. In my mind, I usually use the rule of thumb that I move the buffer 1-2 inches per second.
I will try to make my question more clear and I will use your videos as a reference. Assuming I am using 9-14 lbs of pressure on setting 5 with perfect technique, an orange pad, and M105, how many passes can I make on my clearcoat before being worried about removing too much??
Video 1 in
this thread, 7:43 in. I answer this question in explicit detail.
My question stems from not knowing how thick the clearcoat is shot on a Viper from the factory. I have a 70 Chevelle SS I did a frame-off resto on in which I wetsanded the entire car after paint, but I knew I had PLENTY of clear coat to work with. With the Viper, not the case. I don't want to be too aggressive to get flawless paint, and risk early clearcoat failure in the long run.
If you are using the same exact equipment, technique and products that I use in that video series while following my paint maintenance advice, running out of clear coat is not a concern for you. Now if you CONSTANTLY do that entire process every week because you are constantly creating paint damage with your washing and dust removal procedures, that's another story. If you follow the advice that I give in those videos, the orange pad and M105 is going to be a
one time occurrence in the life of your paint. On the other hand, constantly jacking up your paint by doing all the things that I preach against doing is going to eventually cause you to wipe your clear coat thin. It may take a while if you use a PC, but it will eventually happen.
If you truly want to know how much primer, base coat and clear coat is on your car, then you need to invest in a
DeFelsko 200 C/Advanced paint thickness gauge. Then you will be working with EXACT numbers. No guessing when using that tool.
I have done multiple passes with M105 and am not getting full correction. It is leaving small "dips" where the etching was the deepest. I know you are chalking this up to my bad technique, but it is more the severity and depth of the water etching. I think the first owner never put one coat of wax on the car for the 4 years he owned it, and allowed the hard water to etch deeply into the clearcoat.
This very well could be the case. However, I wouldn't advise anyone reading this to go more aggressive unless they know exactly what they were doing. So many novices read suggestions in these threads and get a false sense of security when trying more advanced paint correction techniques. The next thing you know, they're staring at a paint job. The bad thing is, there are painters out there who can't match color to save their *** and you end up with a 2-tone Viper. Talk about pissed, that is not a good thing to experience.
This is why I stress technique so much. Although it may appear that you are not making as much progress as you seemed to at first, you actually are. It may not be as fast as you like, but at least the progress is safe.
The only advice that I will ever give a novice about fixing his paint is advice that I would allow him to try on my very own paint. If I wouldn't allow him to try it on my paint, I'm not going to tell him to do it to his.
I will use my DSLR and try to take pictures of the before and after to show you what I mean.
So back to the root question... If you were doing a customer's car and it had severe paint flaws, how many passes with an orange pad and M105 would you feel comfortable doing in an attempt to get full correction?
Exactly what I would do is different from what I would suggest you do, as I don't know your level of expertise. If I came across some really bad damage that the PC, M105 and the orange pad was going to take forever to remove, I would bump up to my Flex or my Makita polishers. One is a true dual-action and the other is a rotary. The next step up is wet sanding, as I did on this Viper (mainly due to time constraints). One thing to note, I wouldn't touch a customer's car that required that level of work without my DeFelsko paint thickness gauge. I don't work with assumptions when it comes to someone else's car, I work with exacts.
The damage...
Repair in progress...
The finished product...
So that's what I would do.
