ANYONE WITH A SERVICE MANUAL!!! Please Read ASAP!!!
Cape Coral, FL
I am in the middle of my pan baffle kit... can someone please post the torque specs for the windage tray nuts ASAP!!! I would like to check them all before reassembly.
C O D Y
Vancouver, WA
Not sure what kit you are installing or even if these numbers you need but here ya go... good luck.
Oil Pan bolts 95 in lbs
Oil Drain plug 25 ft. lb.
Cape Coral, FL
I already have those two specs... what I dont have is the tourque spec for the nuts which hold the windage tray onto the bottom of the engine, UNDER(inside) the oil pan.
Cape Coral, FL
KenH- thanks man. you just confirmed what I suspected... now I know I dont have to go retorque them again...hehe.
kc651
