Are there Cutch Shim Kits & bleed lines ????????????
Tim
Leduc Alta
Would anyone know who sells the hydraulic line that runs from the master cylinder of the clutch to the top of the engine compartment to ease in the bleeding of the clutch?
Is there anyone that sells shims to help shim the clutch pedal out on the Gen One cars?
How well do these kits work?
Tom F&L GoR
Wappingers Falls
Don't you want an extension from the bleeder tube at the flywheel up to the engine compartment? The bleeder is positioned after the slave cylinder so that you get the air out of it also.
Do to that, I think you'd have to install during clutch change, though.
Are you looking for more stroke or same stroke+ more clutch disengagement? (Me, too.)
T
Tim
Leduc Alta
Tom,
Yes I wish for a line to run up to the top of the engine compartment and maybe secure near the master cylinder for the brakes. This way it would allow for easy access to bleed the air out of the clutch as it seems like it takes many attempts to get it just right.
As well I had heard that there were shims available to put on the throw out bearing? To help place the clutch pedal out further. Maybe from one of the Archer brothers?
Tim
