I'm interested in what setups people are running for autocrossing. Please identify if you are in an ACR or not ;-)
I'm about to realign the car from stockish (been slacking on doing this) because my competition just stepped up their game at a recent event and I know I must do so to compete. I run a 99 ACR, currently with -.4 degrees neg camber all around, RA1's, unknown toe and castor, and 28PSI hot pressure. This is what I run on the street and really all I've done is to play with pressures over the past few events, settling at 28PSI. Shocks are two clicks from full soft in bump all around, and three up from full soft in rebound in the rear.
At the moment the car is neutral in transitions and above about 50mph, but plows in slow corners. I'm planning on upping the front grip and backing off the rear transient roll stiffness (or upping the front) via the shocks which should reduce the understeer in the tight sections without making it too snappy in transitions and at higher speeds.
I was going to bump up to a 305 hoosier up front (I have an 11" wheel), 335 in back and reset to a baseline alignment of -1.75 camber, 1/8th toe in per side, the high spec for castor front, and -1.25 camber, 1/8th toe in per side rear.
This car is daily driven, so the alignment spec is still a bit conservative for flat-out autocross use, but I'd like to hear peoples' experiences with camber above and below that. The non-acr cars won't directly apply to my setup but I'm interested in hearing about them as data points.
