Belanger header gasket replacement needed
Detlef
Northern Colorado
I have developed a exhaust leak and need a new gasket. Does anyone know if the standard Dodge exhaust manifold gaskets will work with the Belanger headers? If not what should I get as a replacement?
PhoenixGTS
Phoenix Arizona
The factory metal gaskets work and are preferred for the header to heads.
I second what carguy07 said. I blew out a Belanger composite gasket and now have stock metals with no issues.
jk
Richardson, TX USA
Same here. I used the Belanger gaskets and a few months later developed an exhaust leak. Header bolts had loosened over time - I should have re-torqued then after a couple of heat cycles. Replaced with stock metal gaskets - no problem.
repiv
i am on third set of belanger gaskets, if they don't work this time, i will go back to the stock ones. I replaced the header bolts this time, was told that maybe they are stretched
