belt tensioner problem
anton28
how do i know if my belt tensioner needs replacing. My belt shifted for no apperant reason and i cant figure out why, could my belt tensioner be going bad?
X-Metal
Indiana
how old is your belt, how many miles, did you miss a shift? what does the belt look like, any cracks visible in the v-grooves?
bluesrt
if the tensioner spring part is not 100 percent straight(not kocked at the round spring part where is functions)it is weak,will run ur belt not stright,also look on the tensioner pulley to see if u can find a old run pathe from the belt.
AZTVR
Chandler AZ
How has your belt shifted? Has it jumped over so it is no longer in its normal position on all of the pulleys, or just the tensioner?
Here's a possibility, although probably not your issue, it couldn't hurt to check: Make sure that your crankshaft harmonic balancer bolt is not loose.
http://forums.viperclub.org/rt-10-g...crank-pulley-have-come-disconnected-help.html
A
anton28
belt has less then 1k on it. i was driving normal as in cruzing at 30mhp not getting on it at all.
A
anton28
yes it jumped over torwards the fron of the car on all the pulleys. Ive had the balancer bolt get loose on me before but not this time.
Jerry Colpitts
Plymouth N.H. USA
I replaced my tensioner about three months ago.....just worn......my car is a 98 so it is ten years old plus i have the roe also....it is not that expensive of a part either!!!!:2tu:
Atom
