Best and Worst Mods for GTS?
dave6666
Whoops. Forgot I already started filming.
We're filling in the mounting indentations right now to give a 100% smooth underside. Go to pick up the splitter material on Wednesday.
RTTTTed
Would that be effective on the Gen2 stock airbox?
It wouldn't be as effective unless you could get the hot air out from under the hood. Open up cowl, add more scoops, Roe fascia, etc.
It would make a difference insulating the airflow from the radiator and engineblock heat, just not as much as the 08s.
My airbox works like your Vipair and draws hi-pressure air from the front of the rad, which is also enhanced with the Roe front fascia scoop as well. I think there's probably 10-15hp in our cars if we insulated the bottom of our airboxes.
Ted
Ted
Fatboy 18
Surrey, United Kingdom
Right then, my car is going on the dyno tomorrow, I will let you know the results :)
Worst part is though Ive got to drive the car on salt roads and sleet :omg: :omg: 0 to 60 5hrs 10min :rolaugh:
Fatboy 18
So here's the spec!!
2000 gts
Fitted with these,
The car has in its lifetime had an upgraded PCM, And Bellenger rear exhaust box.
Dyno results!!
So what do you think? :dunno:
Puntacanaviper
