Hi,
Today I have tried to bleed my coolant system and am having some issues. As it heats up the water gets pushed into the front bottle and stays there as it cools? I thought it worked on a push pull system that allowed water to enter front bottle as it expands and go back into the system as it cools not just raise the front bottle level? My temperature gauge just keeps on rising up to the red while sitting on tick over and on occasion if i blip the throttle a bit it lowers at an alarming rate ie from near red top to middle in seconds sometimes it doesn't. I have fitted a new thermostat and repaired the hole in the bottom of the front fender bottle. But not sure how the water would ever go from front bottle to pressure bottle in engine bay?
Does anyone think it could be a faulty pressure cap causing the overheat issues as can't bleed air out properly?
The temp gauge is yoyoing too much!
Any other input would be great. Thanks
