Brake fluid recommendation?
Dave's Big Brakes
San Diego Ca USA
I use the Blue Oval :2tu: brand, ran SCCA A/S, and lots of road courses with NO problems what's so ever :usa: Dry boiling is 550', and it's dirt cheap :eek: no Viper Tax added :shocked:
Chuck 98 RT/10
tampa, fl USA
DOT4 not DOT3. If you don't track there is no reason to get expensive track fluid. Advanced (Discount) Auto has qt bottles of Valvoline DOT4.
95Viper
Phoenix
Motul does make great fluid but the only downside is that it is a brownish color right out of the bottle.
Val Syntech is a great Dot4 fluid and clear.
Blue Oval is good too.
Castrol SRF for about $100 is the best.
jk
Richardson, TX USA
Since you don't (or rarely) track your car, seems like Valvoline SynPower (500 degree dry, 340 degree wet boiling points) would be a good choice. Not as high wet/dry boiling points as Motul 600, Castrol SRF, but you don't have the water absorption issue and won't have to constantly change your brake fluid and it is a lot less expensive.
Bill Pemberton Woodhouse
Blair,Nebraska,USA
We carry BrakeMan and have for years , as alot of folks use it that run Viper Days, but definitely use a DOT 4 and not a 3 when you flush. Listen to da folks, and Autozone 3 is not the way to go!
bathurst68
