Brake shudder caused by pad deposits on TA front rotors
Stealth
SoCal
Replacing the front (?) brake rotors after only limited use is pretty extreme. Those rotors (Brembo for TA fronts?) will be quite expensive as I am sure you have discovered. Brake fluid and Brake pads are supposed to be the consumable/wear items. Here in CA, many use the Gen IV ACR rotors for more than a season. Hopefully this will be a one-time issue for you.
Thanks for the reports.
Omaha NE.
Update on the TA pads availability, I should be getting 8 sets via airfreight from Europe very soon for you track guys running short, hopefully they try and keep better stock at Mopar.
Carlos580
