Ok so my Viper is down again. last night I was cruising around and came to a red light. Stopped as usual light turns green I pull up into the intersection, to wait for a car so I can turn. I look to my right as I'm about to turn and see a semi flying at me flashing his lights and blaring his horn. I drop it and take off around the car, barely missing a colison with the semi and I hear a waboom. I thought the semi hit me at first but, was like I didn't get spun out. So I came to a complete stop a little shook up. Tried to move and my right tire just spins. (mind you I'm just barely letting out the clutch with a little gas not a hard start). So I'm thinking to my self "blown rear end". Well that couldn't be the case because I wouldn't move. So I pull in a gas station at idle and hear a crack,crack,clunk, clunk. Get out and wiggle under the rear end look up and notice the half shaft isn't hooked together. Which brings me to the conclusion blown half shaft. So my question to viper gods is... is it my driving or my luck??????? clutch and now a half shaft? because I don't know any more.
