Calling all Roe S/C Software users!!!
Snake Eyes
Has anyone been exchanging (emailing) VEC2 files and comparing them. I would like to see some of the other files people are loading. :2tu:
kverges
Dallas, TX USA
not running that much boost, but happy to share timing & fuel curve info. In theory, the load tables should be similar up to 5-6psi boost, since the VEC-2 is MAP-driven.
Starting with 4000 rpm, do you run advance at 5 psi?
Joe Dozzo
Golden, CO
I'd be happy to share as well (7psi and 50 lb injectors). Be prepared to send your VEC2 code and serial numbers, BTDT...
1TONY1
Dalton Ga. (Chatt. Tn.)
I don't think you will need my code and serial to put the program on your card with your code. You want to send yours or I can send you one and we will give it a try.
Sean Roe
Jacksonville, FL
Actually, you can toggle the Box Serial Number field to "Unlocked" and save the file for sharing. I save all the files that way, then just plug in the Box Nr and Encryption code when burning cards.
Another thing that might make it easier for you guys is to chose the "Unlock After Upload" option when you burn a card (you would still need to use your Box Nr and Encryption Code when first doing this). After uploading the card into the VEC2, the VEC2 would then be able to read "Unlocked" cards with no specific Box Nr in the field. Just keep in mind that the VEC2 will then be capable of reading any Smart Card, even ones you may not want it to read.
We plan to add a "Download" page to our site with all the most recent programs after we finish the move. On that note, e-mail, internet and phone may be out for the next 2-3 days.
Regards,
Sean
fast?
sin city
anyone running 7lbs on a 2000-2002? i had my car tuned a couple weeks ago at dyno-jet in vegas. with the help of sean after the dyno we proceeded to up the spark advance.
i am having to add 15% more fuel under load and 10-15% more fuel @ 3000 rpm and up form the revision 8 card.
what a/f ratio is everyone running,11.7 or closer to 12?
damn cast pistons are holding me back from making some serious power.
ViperGear
