Calling all ROE SC Vipers
SUN RA KAT
Guest
Stock rockers, stock gears, VEC2, S&B filters with 70 mm smooth tubes, Roe 70 mm air box, 70 mm throttle bodies, Belanger Headers, Randon Tech Ultra high Flow Cats, Corsa 3" Cat Back, Roe fan timer, lightweight flywheel, MGW shift knob, Woodhouse modified shifter, & Roe Supercharger #35.
436 rear wheel HP & 480 Torque before Roe Supercharger. See below signature for dyno measurements before the new & improved VEC2.
Jerry Colpitts
Plymouth N.H. USA
Roe Supercharger #17 stock rockers-1.7s would not just bolt on without headwork 70mm throttle bodies 70 mm smooth tubes vipermed airbox b & b headers random high flow cats 3 inch corsa cat back system delrin suspension bushings eradispeed rotors ebc pads stainless steel brakelines msd wires march billit pulleys heavy duty half shafts :cool: :cool:
fuelman
Lake Mary, Florida USA
I did the T&D 1.7, but I did them before the Roe Supercharger. My car is 2001 and the rockers made a big difference, the car went 11.97 at 120 mph. I have a Corsa, no cats, and stock exhaust manifolds. Car runs strong, at V-10 Nationals on drag radials I went 11.13 at 127 mph with the 5 lb charger. I would go with the rockers before headers. I think it is one of the mods that Sean recommends for the super charger.
Moundir
Ny
I'm wondering what other mods you did while installing Roe SC. Did anybody do 1.7 rockers, gears, headers...
oh uh, I'm dead meat :(
VIPERCANE
Winter Springs, FL, USA
ElDiablo, I have the Roe SC and the 1.7 RR..........Macedo installed it with no problems............I also have TNT Headers, Borla exhaust, 70mmTBs, no cats.
