Can someone check if a recall has been done?
Bird325
Ft Worth, Tx
Does anyone have access to the Dodge system that can check if a particular recall was done on my new (to me) '01 GTS? If seen a thread about the recalls on the car that said something about a problem with the PCM/ECU causing PING. At times, I get heavy ping above 4K RPM when under passing load. If the recall hasn't been done, I'm going to see if the Dodge dealer will honor it.
My VIN is 1B3ER69E91V702109
Thanks for any help that can be offered.
B
Bird325
Ft Worth, Tx
THANKS! The site says they are all complete which is what the previous owner told me prior to purchasing. So now, I'll have to deal with the PING. May be another bad tank of gas? I'll do some searching and see what I can come up with.:dunno:
Tom Sessions
Hampstead,NC.
This car has no recalls that apply to it. There is a TSB for spark knock if using 91 octane fuel. The fix is to reprogram the PCM. I would be looking for some other problem. Old fuel plugs Wires.Fuel filter. Intake manifold leak vacuum leak.
NUMBER:​
18-019-03
GROUP:​
Vehicle
Performance
DATE:​
May 2, 2003
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retreival system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation.​
THIS BULLETIN IS BEING PROVIDED IN ADVANCE. THE MDS2 MUST BE OPERATING
WITH CIS CD2133 OR HIGHER, AVAILABLE MAY 26, 2003.
SUBJECT:​
Flash: Engine Spark Knock Using 91 Octane Gasoline​
OVERVIEW:​
This bulletin involves selectively erasing and reprogramming the Powertrain
Control Module (PCM) with new software.​
MODELS:​
1997 - 2002 (SR) Viper​
NOTE: THIS BULLETIN APPLIES TO DOMESTIC MARKET VEHICLES.
SYMPTOM/CONDITION:​
Vehicle operator may experience engine spark knock using 91 Octane gasoline,
when accelerating at medium to heavy throttle.​
DIAGNOSIS:​
Using a Scan Tool (DRBIII​
®) with the appropriate Diagnostic Procedures Manual, verify
all engine systems are functioning as designed. If DTCs are present record them on the
repair order and repair as necessary before proceeding further with this bulletin.
If the vehicle operator describes the Symptom/Condition and is using premium
91 octane gasoline, perform the Repair Procedure.
B
Bird325
Ft Worth, Tx
Great, now where do I start? The plugs are new and I'm running 93 octane (10% ethanol). Since this doesn't happen all the time, I'm going to start by assuming that it's fuel related (not all gasolines are the same).
I have a new fuel filter and plug wires, but not really looking forward to tackling that at this point as I'm not that familiar with the mechanics of the car yet. Muscleheads is on the other side of the Metroplex and I'd have to take a day off work just to go over there.
I'm planning on getting the SCT Flash programmer for Christmas, so maybe starting with a fresh programming may help?
Recommendations?:confused:
B
Bird325
Ft Worth, Tx
I was actually just out in the garage looking at the task and will probably do it this afternoon. Looks like you remove the windshield plenum (4 screws) and that should give good access to the distributor. Opening the wire looms isn't obvious. Can they be done by hand or does it take a small screw driver to release the latch?
Also, should I use di-electric lube on the boots or not?:confused:
97snk
Great info. I just ran my VIN and it says:
Description Type Issue Date Status
STEERING AND DIFFERENTIAL FRAME REPAIR
SAFETY
05/16/2002
INCOMPLETE
So should I just take in to a dealer to get it done...
No members online now.
JpKL
