can the cam be removed in situ?
carl B
United Kingdom
Can you jack up the motor out of the mountings to get enough clearance to slide out the cam? Gen2
Carl
Viper Wizard
South Salem, NY USA
Hi Carl,
You'll need two jacks because you have to disconnect the rear trans mount to get enough angle to clear the front cross member. But BE CAREFUL it gets a little tipsy with two jacks! :eek: I have done it.
Cheers
jk
Richardson, TX USA
I removed the cam in my Gen2 with a single jack after unbolting the engine mounts, but the cross member was removed. I had about a half inch of clearance before the cam hit the AC condensor. (I had to unbolt the top of the AC condensor and lean it forward a bit to clear the cam from the engine.)
