V10SpeedLuvr
About a year ago, my gas mileage started getting really funky. It'd be anywhere from 12-22 on the highway (normal 6th gear, 70-80mph type driving). Replaced one upstream oxygen sensor and that got it to a steady 18mpg. Replaced the 2nd one and that got it to a steady 22mpg. After a couple months, its doing the same thing. On my recent trip to FL, my gas mileage was 18-ish mpg on the way down there. Before leaving, I filled up. When I stopped on the way home and topped off, I had gotten 22mpg on that tank. When I filled up again after I got home, it was only 15mpg.
Took it to Dodge yesterday and they put the scan tool on it and said all oxygen sensors are switching and short term fuel trim looks good. They said what concerns them is my injectors were "jumping all over the place". Tony Armour has already cleaned and flow checked them, and said they were fine, so I don't believe the problem is with the injectors themselves.
I have Borla Headers, Moroso Spiralflow mufflers in place of the OEM cats and no rear muffler.
I am running one OEM oxygen sensor and one oxygen sensor from DC Performance b/c they have extended leads and the ********* on my LH header is further down and an OEM sensor won't reach.
The tech at Dodge said with me being catless, the rear oxygen sensors (both OEM) are confusing the PCM and it is sending all sorts of crazy signals to the injectors. He recommended rear o2 sensor simulators, or high flow cats. Never had a check engine light.
Does this sound right or anyone else have any suggestions?
