Catch can install finished
TowDawg
Chattanooga, TN
Finally got all my parts together and knocked this out.
Honestly, the biggest pain in the butt was finding a 37/64 drill bit to drill the new whole that needed the 3/8npt tap put through it.
I ended up tapping the original holes and putting a plug in them to seal them up. You'll never even notice them after I get the valve covers powder coated this winter.
I definitely had some oil residue in the original lines so the catch can will be worth it.
MTGTS
Orlando, Fl
What catch tank is that? I'm getting ready to make a dual vent dual catch can setup for my car.
T
TowDawg
Chattanooga, TN
345, there was plenty of oil residue in my stock lines, so I have no doubt that this thing will be doing it's job of keeping that crap out my intake.
Matt, it's just a cheap $30 can from ebay. I wasn't too worried about a high end can since I wasn't running back to the PCV anyway. All I wanted was two inputs and a filter on top, and this one fit the bill. The fittings and line was definitely more than the can itself.
VIPER GTSR 91
Spring, Texas
Looks very similar to my recent ACRX can installed by Tomball and at a great price. They even did the valve cover fittings right there. Can was mounted with a bracket on the passenger side forward in the engine bay just aft of the radiator. It has a drain at the bottom.
Chuck 98 RT/10
tampa, fl USA
JMB Performance will build one for you with drain and with or without a sight tube in various powder coat colors. I got mine without the sight tubes. I like the JMB because they are nicely built and the smallest ones I could find. If the connection to the valve cover is strategically placed you won't get enough oil to fill up those big ol' tubs most places sell.
Black Moon
Knoxville, TN
Finfshed mine as well.
No members online now.
JpKL
