Change the oil before you put it away. Driving it a few times after it is change will not hurt. Once coming out of hibernation, no need to change perfectly good oil again, wait until hibernation time comes around. Full tank of gas, battery tender, place plastic tarp under the car, inflat tires to almost max PSI, put a car cover over it, some mice traps would not hurt. Every 4 weeks or so, put the car in neutral and roll it to a new spot so the tires do not flat spot....this probably will not happen, but I just do it for my own analness. Do not start the car and let it warm up to operating temp and then shut it down..not good for the engine and other parts. Do not drive it unless the salt is off the roads after some good steady rain. If you do take it out, make sure you can drive it for 20 steady miles at operating temp. These are the things I go by, so everything listed is just me. I am a new viper owner of less than 2 years.
