Jog
As you all know..The NARRA has a couple of Track events scheduled for VCA Members this year; so if anyone would like to attend but needs a racing helmet, here's the place to look. After countless hours searching on line for helmets, I was shocked to find out how much a helmet would cost ( they range from $300 to $900 ). I was finally able to find a website that had a reasonably priced helmet. The helmet can be found at: saferacer.com and it's called: Zamp (model# FSA-2 SA2010 / Part# H714035L ), the helmet lists for $169 ( brand new ) with free shipping, but you can use a discount code sm0125xrp ) and get %10 off. This helmet is Snell Rated and complies with the SA-2010( year) specs. If your not sure what size you need, you can use a tape measure to measure your cranium and compare it against the size chart located at the bottom of the page or when in doubt you can always call customer service and they will walk you through the process...I hope this info works for you...Be Safe!!
