Check engine light again!!!! Idle & stalling again!!!!
pdmracing
Atlanta Ga
My car has a reoccurring problem with the Idle. Its a 97 GTS with 31K, every 6 mos or so this happens & it happened last night.
Problem, Idle goes to 0 on tach , then bounces back to 450 rpm or so (indicated), then run fine.
After a few days of this , last night after work, after a 60 degree day , the temp was around 39+- , the car started ok , but the idle thing happened again, & this time it stalled 5 or 6 times, on the short ride home the check engine light came on .I think its showing a code 12 & 14.
The dealer has replaced many parts & the car runs fine 99.9% of the time. Any advice?
Try a new battery. Every 6 mos the weather gets cooler. Every 6 mos you have this problem. Honestly, try a new Die Hard
Gerald
Near Tampa Bay
I just went thru the same thing... twice.... symptons were exactly what you stated.... Problem with mine was for some reason a spark plug boot came loose... Pushed it back down and car had to relearn to idle for a couple hours and now runs great.. Couldn't hurt trying.
keep us posted..
Gerald
P
pdmracing
Atlanta Ga
Jon, I was thinking battery myself, its the original & has never let me down, what should I buy?
Bandit3
Atlanta
Pete- I've installed an interstate MT-78. Works and fits fine. My car sits for extended periods and has never discharged. Contact me- I sell them at my shop-- give ya a great price- my cost! BTW did you do me the favor at Petit LeMans with the Viper Club parking pass? Someone left it on my dash. If not, thanks to whomever.
P
pdmracing
Atlanta Ga
Put new battery in & so far so good!. The old batterey was the original 97 & had never failed. The case looked alittle bowed but the green light was still lit. The voltage gauage is reeding higer with the new battery.
Thanks for the tips
