clunk from rear of car
Vic
Anybody had this problem?
When I roll out of my driveway, I hear a clunk coming from the rear of the car. Seems to be happen when torque is applied to the rear wheels.
Viper tech changed the diff, no help. He said he didn't see anything loose in the suspension.
Play in half-shafts? Undersized swing arm bushing?
Cape Coral, FL
are you SURE its not the transmission? Also, check the joints on the Driveshaft, and both the Axles.
Magicboy2
Philadelphia, PA
I also have a clunk... it's in the shop today for it, in fact. Noticible when I shift. I originally suspected it was an exhaust pipe loose, however the dealer just called and said it's the cross member bushings. We'll see if fixing those does the job....
By the way, does $150 (1.5 hrs) sound reasonable for replacement of cross member bushings?
Vic
Vic
Thanks for your responses-I'll post back when the problem is solved.
Magic Boy- Sounds reasonable to me.
Vic
Vic
So far, here is whats been done-
1. New Differential
2. Swapped driveshaft, no results
3. Tightened motor mounts, transmission mounts, differential mounts, exhaust fittings, sway bar joints and mounts, shock absorbers, brake calipers, wheel lugs, swing arm pivots,
4. Checked frame for cracks, none found
This sound started abouth the same time as my transmission was changed, 2000 miles ago.
It clunks when stressing drivetrain, but its not the same sound as the drivetrain backlash. This sound is bigger, louder, more dramatic, and more noticeable. Seems to happen when two things are happening at the same time- Suspension is being flexed, AND, torque applied to rear wheels.
If the suspension is flexed, rolling over undulations in the pavement, but without any torque applied to the rear wheels, there is no sound, other than the very minor sounds of the chassis flexing.
If the car is on a level surface, and torque is applied, there is also no sound, other than the usual and typical drivetrain backlash.
But if you flex the suspension, AND apply torque to the rear wheels, the "clunk" sound rears its ugly head.
Theory- Although the differential is rigidly mounted, it is still subject to rotational forces, as the pinion gear tries to climb the ring gear. The effect of this force is transmitted to the differential mounting brackets, causing them to flex. As the differential moves slightly in its mount, the driveshaft spline going into the transmission is not allowed to accept the resultant slight fore-to-aft motion of the driveshaft, putting it in a bind, until the fore-aft-force overcomes the bind of the driveshaft under torque. Possible? Normally, I wouldn't suspect an obscure cause off the bat, but this one is not typical. No one seems to have any answers. Unless I can think of something else to chaeck, the car will go back to the shop for warranty repair. (Again)
GR8_ASP
I remember hearing about rear driveline clunk that came from the fit of the rear spindle fit to the driveshaft. I think there was a TSB on it long ago. All they could do was fit a tighter fitting spindle and tighten the spindle nut to the maximum.
Vic
Vic
Thanks, Ron, I'll check it out.
MOUNTAINWOLF
Blue Ridge, GA USA
I have something similiar. Not loud or harsh just feels like a ball joint or tie-rod end on the front going bad, but it is in the rear of the car. Like you said, only when torque is applied and the suspension is in a flex position. Mine seems to only happen when turning to the right. Has not been bothersome enough for me to take to dealer, but I am thinking about it.
Vic
Vic
Mountain wolf-
Funny you should mention that- I only hear mine when turning to the right as also.
