clutch disks for high HP
SNKBYT
E.SWANZEY, NH
What is a good clutch disk(better than stock) :cool: to use with Supercharger or cars that produce high horsepower. I'm adding a supercharger and need to change the clutch. Any comments with products that do or dont work would be helpful. Thanks
pauls
Akron, Oh USA
I've gone through 2 stock clutches (original was great the replacements are junk) and centerforce that wouldn't release at high RPM and now have a Spec stage 3. Can't comment until it's broken in.
9 seconds
Texas
I put a Spec stage 3i in my srt-10 Ram on the advise of RSI. I too am breaking it in.
PhilC
Jackson, NJ, USA
I agree with Pauls that the replacement for the stock clutch is terrible. I didn't find the kevlar clutch from Archer all that much better.
I will wait to hear the feedback from you guys trying the spec stage 3i. Hopefully it is the answer I've been looking for.
Good Luck.
Phil
Pat_L_96GTS
Milan, OH
Just curious, are the replacement disc slipping, the cover assembly failing or both? Disc and cover assembly should be replaced together, but that isn't always the case. There are many different materials that can be used on the disc facing that may solve some problems. Also, different things can be done to the cover assembly to achieve desired results.
wizzlepoof
