DViper
I have about 1000 miles on the clock and recently found out that the car won't shift above 5000 rpm's from 3-4 or 4-3 about 50% of the time. The symptom appears after 2-3 spirited runs, otherwise it's fine. It shifts out of gear just fine, but there's no gear to be found at higher rpm's. I didn't experience any grinding since I won't try to force it, and I don't power shift (ever).
I realize this should be a warranty issue. But, Just how exactly does one go to the dealer and tell them that their car won't shift at 120mph? The problem doesn't occur at lower speeds or rpm's.
My guess is that the clutch is slipping a bit and boiling the clutch fluid in 3rd and 4th gear, causing the clutch to not fully disengage.
Any idea's on the best way to approach this with the dealer? They can't replicate it unless they do several runs above 100mph (which I don't want). The car is less than a month old.
Any help or idea's would be much appreciated.
Thanks in advance
Thanks in advance
