MoparMan
Does anyone know for sure which O2 sensor is triggering code P0152? I think it's the upstream passenger side O2 but I want to know for sure.
Mopar Man......have you installed after market headers? If so, the same thing happened to me, and it was because the "wiring" for the O2 sensors was too close to the back header tube, and it "heated" the wires up, causing resistance impedence, which threw the code. Once I moved the wires away from the header tube, and covered them with high heat tape, 10 miles of driving and the check engine light went out! Hope this helps.
