Glad to see our Viper come out on top. Sounded like the most fun and exciting to drive too. ViperNation should be proud.
Was surprised to see the BMW M3 so far down the list.
Thanks for posting. He seemed very fair with his comments. At the end I was left with the question of what the new Z06 or ZR1 will do on a road course. The statement regarding the 6 tenths of a second difference with 180 HP less is noteworthy. Your thoughts?
In case you don't want to watch the whole video to see the times:
SRT Viper - 01:23.9
Corvette Stingray - 01:24.6
Nissan GT-R - 01:25.2
Porsche 911 Carrera S - 01:25.6
Porsche Cayman S - 01:27.0
Shelby GT500 - 01:27.3
BMW M3 Coupe - 01:29.0
My thoughts: a longer, faster track will make HP a bigger factor in lap times. If you can't use all of the available power because you run out of room, then it does you no good.
If anything, I think it is a testament to how well-rounded a Viper is that it can do better than a Corvette on a short(er) course, especially with how driver-friendly the previous Vettes have been (I'd assume the C7 is no different in this aspect).
Good points and very noteworthy indicating the new ZO6 or ZR1 btw a better match for the Viper will be the King and make well over the 6 tenths lost.Thanks for posting. He seemed very fair with his comments. At the end I was left with the question of what the new Z06 or ZR1 will do on a road course. The statement regarding the 6 tenths of a second difference with 180 HP less is noteworthy. Your thoughts?
Well done for the Viper. I still was expecting even more difference with the Vette.
Still, the lap times are not impressive.
Randy has done a 1:19.5 with the GT-R 2013, and Z07 Package has done a 1:20.43
You guys are missing the point. He clearly stated that this test would be objective, and based on the same driver, same track, same day. The results are relative. They shouldn't be compared to record-setting runs by pro drivers. That wouldn't be relative, in a comparison test. If Probst is better, and did the same series of tests, then his times would likely also be relative, just with all the times being quicker. The net results would likely stack up, just as this guy's did. Arguing semantics is a waste of time, the video is for your entertainment.
After having tracked my "base" Gen V this past weekend, the car definitely has more power than it can use on a road course. I was mostly in 3rd gear, and couldn't even floor it when doing my exits. If I tried flooring it while in any sort of turn, the rear would step out and the inside tire would haze. So, it was part-throttle until the car got mostly pointed straight. If the car made 150 hp less, it would likely still turn the same track time on a smaller technical track.
Tony,
A Giken diff would totally eliminate this issue although it would probably mess with the stability systems :-(
Few people here could drive any Viper to its limit ( I can't ), so maybe this comparison is actually more valid to the readers/audience. The pro drivers don't purchase their cars based on what magazine drivers tell them, nor do I.
This is true, the Corvette's limits may be more approachable because it communicates better. The Viper might have a lot more in it but it can be more difficult to achieve. Does that mean the driver isn't brave or skilled enough? Or is the vehicle not giving the driver enough information about what is really going on?
http://jalopnik.com/5969087/ralph-gilles-calls-out-motor-trend-driver-for-being-afraid-of-the-viper
Hard to say, but I'm thinking that there's more suspension tuning that can be done for the Viper to be even more communicative with the driver about where the limits lay. Having only a single year and a limited budget to get the entire Viper program resurrected probably means a lot of refinement and tweaks can be done to make the vehicle's suspension communicate clearly. The C7 development mules were out and about since 2010, and Michelin took 3 years to get the C7 tire program going, so there's a lot of homework that Chevy got to do to make the new Stingray handle as good as it does.
