JeffTheViperMan
Alright, I'm kinduvan audio Guru when it comes to signal paths and wiring... But this might be a bit above my level of experience.
I noticed during the Covered Bridge Tour this past weekend that my radio crackles pretty bad when I'm not moving - like sitting at a stoplight or intersection. But then I also noticed it during some of the down-hill portion of the tour - I would shift out of gear and let the GTS coast in neutral, and the crackling would start again. If I blipped the throttle the noise would go away for a moment until the engine returned to idle.
What the heck could it be?? That I know of, the dash has never been removed - the original owner never did any funky wiring on the car. The only thing I noticed was that there is a green wire in the trunk right near the amp that isn't connected to anything. It comes from the body, not from the amp, from what I can tell. I haven't had chance to check if it's attached to ground or if it's hot - or either of the above. I can get a pic up if that'll help.
I'm guessing I have a bad ground or a short somewhere, but the audio works just fine when I'm driving. Any ideas??
Jeff
Jeff
