Fatboy 18
OK need some advice from you guys that have rebuilt engines.
First off I am no engineer, I can pull things apart and have in the past replaced Timing cover gaskets, Half shafts, UJ's, Engine mounts etc. But Have not ever pulled the heads on an 8ltr V10 engine or taken out pistons.
If I were state side I would have no problem taking it to a Vendor here, but being in the UK apart from Viper Baz UK, there are very few people I (if any) I would trust to work on my engine.
Car has now done just over 66K and when I check the oil it always gets dirty very quickly. When I change the oil I always drop the pan and clean that out too so there is hardly any old oil left in the engine to contaminate the new oil.
I do have a tendency to keep the engine on cam (it sounds better with a fully de-catted exhaust) and I do not ever really drive the car sedately (its a weekend toy race car and I use it as such).
Here's things that I have noticed.
1/ I do not have a catch can set up. I did buy a can but Trying to work out how to plum the thing I found really complicated and so its sitting on the garage shelve and I've not really had enough time to work it out
2/ I have noticed the throttle body butterfly's have a film of oil on them, so there is evidence of the car sucking oil into the engine.
3/ I have purchased a set of Valve guide oil seals, but if i'm honest I am not confident about fitting these so these are also sitting on the shelve.
4/ Car is using oil, I guess about at least 1QT every 1000 miles. If the cars engine is running at tick over you do not see any blue smoke out the rear of the car, but sometimes if I put the pedal to the floor when driving you sometimes get a little bit of light blue smoke, but not always.
5/ I do enjoy going down through the gears and letting the engine perform the braking, so I guess I am drawing oil up from the crankcase which may be getting past the rings and therefore is the likely cause of my problem?
I have tried to do a leak down test and compression test but this is very hard with one person and have got non conclusive results
Don't get me wrong, the engine still pulls like a train and the car is a blast to drive but I think the writing is on the wall for some engine work.
I also have a set of Bellanger headers to fit, but I do not want to fit these if I have to pull the heads off the engine as its more expense on gaskets etc.
I have also purchased from a UK Viper member a set of Diamond forged pistons and Total seal rings, which are also sitting on the garage shelve for a rainy day.
I do not have any big end shells or con rods, bolts etc.
So where would you start? The last thing I want is for the engine to get damaged.
