Custome Gen4/5 S/S Header Build
SRT09
Edmonton
So after doing more and more thinking on what changes were going to do on the head. I took a look at my current exhaust header combo M&M headers and my own custom 3" exhaust. I think I'm going to jump into building a custom set of headers for my car in hopes of getting the most out of the car. Pulled the old headers out and I think there is a lot of room for improvement. I've fabricated a lot of exhaust systems and headers just never for the Viper so ill try to document it as well as I can :)
Think after taking a look at the merge quality on my old headers etc there should be some good room for improvements!
Here are a couple of Pics I took of the build so far still waiting on my material to come in from various suppliers. Let me say one thing that material alone is a huge cost phone Burns or somewhere and ask for a quality S/S 5 into 1 Merge collector and expect to pay over $1000 just for a set of high flow merge collectors.
Looks like a lot of areas to pick up some improvement
Inside view of one of the formed merge collectors
Inside view of one of the formed merge collectors other angle
SRT09
Edmonton
Pics of a manifold I just build for my other car recently.
SRT09
Edmonton
So this is the start of building the fixtures for the Gen 4/5 headers.
transferring flange bolt pattern to Fixture
Dbl checking flange pattern with old headers
About2bite
Awesome! How are you bending the tubing? $1000 for a pair of ss collectors? wow that's crazy. What grade stainless? How much time you have invested and how much time do you plan to invest in these headers?
SRT09
Edmonton
You can only buy the S/S already mandrel bent and cut and fit it together. Yeah a well designed 5 into 1 merge collector is a lot of work and time. I will update this thread as I have just received over $2000 worth of stainless, and I still don't have header flanges and some other flanges I need to have custom made for me. Getting the firing pattern where I want it and equal length as close to possible is going to add a lot of time to the fabrication but I think it will be more then worth while.
SRT09
Edmonton
Got a bunch more work done still waiting for my custom Header flanges to arrive :) Wow a lot of work so far, I'll update some pics soon once I'm on a real computer!
SRT09
Edmonton
Working on some new CnC'd Header Flanges for the Gen 4/5 application
SRT09
Edmonton
Some pics while getting the collectors finished off!
SRT09
Edmonton
Made some huge progress today I think these headers flanges turned out way better then even my wildest expectations!
Starting with a big chunk of 304 :)
Doing work!
Bling!
SRT09
Edmonton
Finally got a chance to work on this again over the weekend and am happy to say the Drivers side is built and test for and the passenger side is built awaiting test fitment when I get back in town
SRT09
Edmonton
Quick pic just pulled them out of the fixture to test fit before final welding!
SRT09
Edmonton
To answer some PM's these are a stepped header design long primary's as you can probably tell from the pic. I will be trying a few combos to see which is the best overall!
SRT09
Edmonton
Not much extra room to play around with
v10viperbox
San Diego
That is almost too pretty to bolt onto the car. I have never seen a 5 tube flange like that it must have cost a fortune to have made with the inner peak.
SRT09
Edmonton
Thanks its a parallel merge collector with a reverse cone should be a real smooth transition. In a header one if not the most import HP factors is the collector design then Primary length and then size.
SRT09
Edmonton
Some pics of welding as the headers are in for coating as we speak :)
Couple of pics of the test fitting before coating!
Camfab
SoCal
Looks like you did a great job! Did you buy those collectors from Burns or did you make them yourself?
SRT09
Edmonton
Thanks and no nothing was bought from burns everything from the flanges to dbl slip fits was done in house!
SRT09
Edmonton
Hopefully things work out and I get a chance to get these things installed and build the exhaust in the next week or so
Estespropaint
