daylights issue ?
MbnViper
They delivered my 2014 TA few hours ago and when I was checking it I found out the right driver side daylights not working :( I unplugged the main cable and plugged it again same thing.
The main left lights works fine just the left driver side daylights.I wonder if someone came across such issue and if anyone have access to workshop manual to see if there is any wire I'm not aware about or a troubleshooting guide I will be thankful.
Mbn
past ohio
Ohio VCA
What did the delivery driver say ?? Did you call the dealer that supposedly did a preservice check sheet before delivery ?? Good luck !
habeb
Your local dodge service center is likely your best bet. With a wiring schematic, can't imagine it taking more than a few minutes to confirm DC voltage is present at the terminals driving the driver's side daytime LEDs.
labtec
Maryland
don't know if the Viper daylight lights turn off when the same side turn signal is engaged like some other cars but if so it could also be related to the turn signal circuits.
M
MbnViper
Dealer called and it's going to be replaced under warranty.:drive:
Thanks guys.
Kkustelski
